Hard to tell since the dots on the cam are not visible
2006 ltr 450
Youll need to find TDC. You will see a line with a "T" to the right of it. Center the line with the arrow on your inspection hole. That should orientate your cams, dots will be at 9 oclock and 12 o'clock on left cam. Dots will be at 12 o'clock and 3 oclock for right cam. Theres two TDC marks, but only one will show the proper dot orientation. Hope this helps! Going through the same process currently!
