Can anyone explain what will happen to the oil pressure if the bearing next to the clutch release shaft ,with the seal on one side is not there, so I basically installed a bearing without the seal?
I think the pressure is too low to push through the drive shaft and delivering oil on the right hand side of the engine ,meaning no oil on the clutch side...can anyone confirm or is it ok to run like that?:rolleyes1:
I don't know of any such seal, will need more info to figure it out. check the LTR manual.
