I'm putting the dasa on my quad with a trinity air filter kit and the pim is the air fuel going to be ok?
Probably has been addressed before but I was just wondering.
As long as you dont cut or modify the air box and only remove the lid. You should be fine with the DASA pipe, Trinity pro-flow, no air box lid and cherry bomb. Adding a PIM set on the no sparky setting will add HP and should make the A/F really close. Ofcourse dyno tunning is the best way to make sure you are making peak Hp and have the correct A/F.
I figured it would be close with the pim but I wanted to make sure. No need to puke the top end out.
