2006 - mods 13:1 piston, Athena cylinder, exhaust, removed air lid, external fuel filter
bought the bike with the above mods, no issue for 4 weeks. the past 3 days after the atc warms up it will randomly bog when trying to accel and it you try to force it the engine dies. if you restart it is good for maybe another 5 mins of ridding and does it again. i am assuming something is getting hot. any thoughts?
Check your fuel pressure regulator and make sure you have that plate that’s under the gas tank cause you don’t want your gas to heat up going into the injectors etc
