So I'm working on this bike, I have tore it down and put it back together 2 times now, 13:4.1 ( might not be exact) piston, changed lower cylinder and head gasket 2 times, checked all oil pumps, changed both left, return, pumps, have oil returning to the reservoir tank, no oil out of the top right side oil pressure check screws,
It'll pump oil into the cylinder and out the pipe so fast that with 1 minute of run time it'll be between 100ml-200ml low on oil.
I've been super clean about my gasket surfaces, I've blown out all the oil passages, torqued and double checked all not specs, check good all piston ring gaps, ring position is for sure correct.
I've never been this stumped on something.
Am I missing something?
I've had off both case covers and cleaned blew out oil passages, is there a specific place that a blockage might be that will cause this much oil to be pulled in by the position? Or maybe there is a reason for the oil pump to push the oil by the gasket?
I've been researching this problem on here for over a week, I think I need so help, Ive rebuilt engine many machines and never been so baffled, this is the first ltr450 I have gotten to work on and this is killing me,
I do not know the reason why this machine needed a rebuild but I got it have put together and I think I'm out of trouble shooting ideas.
