1 - 7 of 7 Posts
Just bought a 06 LTR450… looking at first mods with it. Pretty sure it’s mostly stock, but haven’t gotten to far into it…
QUESTIONS
Q. 1: What first mods should I do??? New to the whole ATV world… ANY AND ALL ADVICE / HELP appreciated.
Q. 2: What’s the difference between a pc5, pc3, and cherry bomb / other programmers / tuners??? I don’t know much about the programming / tuning world so I’d like one that I don’t have to program or go into and mess with. “plug and play” if you wil
Q. 3: Doing a swirl filter change, oil / filter, and air filter, and brakes. Should I do anything else while tearing it apart??
Q. 4: Read into a swirl filter delete, and 50% say do it and the other 50% says it f*cks your fuel system up and to not do it. Should I do the delete or keep it??? Very confused there
Q. 5: What suspension mods should I do down the road??? It looks like everything’s getting tired with the suspension so I’d like to redo that sometime soon.. read about stabilizers and aftermarket a arms and whatnot, and idk much about that stuff.. I’d love to learn… what do y’all reccomend???
what other little mods are there that help out a lot?
ANYTHING THAT I MISSED, PLEASE ADD / LET ME KNOW… ANY HELP APPRECIATED!!!
Q1 all depends on what you are looking to get out of the bike, if you want more power I would say a programmer, exhaust, and intake. But if it has all the power you want I would say suspension. The first thing that you need to check on is if the bike has a shift pin locator bracket due to the weak point on the case, if it isn't done you should do this first.
Q2 The cherry bomb was something that Yoshimura sold and it changed your fuel mapping and all you had to do was remove the baffle from the stock exhaust and remove your air box lid and you got a nice power gain from it, I believe it would also be a good tune if you used an aftermarket exhaust. I'm not to familiar with the PC3 or PC5 but I believe the PC5 has an auto tune function that you can use if you can't get your bike dyno tuned.
Q3 Its always good to change out your spark plug and check your valve clearance, if this is a used bike you never know how well it was maintained.
Q4 I run a inline filter, easy to change and I never ran into any issues with it. If you don't want to run an inline filter then you should run an aluminum fuel bowl so you don't run into any of the fuel issues that a lot of people ran into.
Q5 when it comes to suspension it all depends on the kind of riding you do and how much money you want to spend, re-valves are good but so is long travel.
a lot of people don't come on here anymore but there is a lot of good information on here, just use the search function and you should be able to get help with any issues you run into. Congrats on the new bike!
QUESTIONS
Cherry bomb and toss the lid, but that sort of depends on what terrain you are riding.
QUESTIONS
The cherry bomb is just a plug in tuner that is meant to work with the intake lid removed and the exhaust insert removed.
PC3 you would load a program onto the tuner for optional add ons, there was a lot of downloads available online for specific adds ons. Such as a certain exhaust mixed with a certain intake, etc. It is also capable of running a full on custom tune.
PC5, as best I can remember, is all the 3 can do but it has an OB2 reader and can write it's own gas map. I only had the 3 so someone else would need to comment to correct me. It did have an OB2 reader and bung that would have to be installed for certain.
I never used any others or recall posts about them to comment, but don't pass up reviewing them.
Nailing it. Check your chain and sprockets too. If you're riding all woods or short fast sprints it wouldn't hurt to increase a tooth on the front sprocket. As well as up an inch in the rear tire, if you're riding rough terrain mostly. I think I was running a 13 tooth front sprocket, stock rear, and 22" rear tires. They were new at the time in 2008ish but Maxxis 10 ply, rears, but I rode almost all woods. Can't recall the model of tire unfortunately.
I can't recall if I changed mine, I think I did, but I don't think I altered it.
/QUOTE]
I've got zero input on this one, but for fun, Lonestar stood out using good steel but I can't comment on a good brand for current times.
1 - 7 of 7 Posts
