So I bought this bike newly rebuilt. Also it had a bad starter easy fix then it burned up a new 1 turns out that the both cams were off 1 tooth okay got that fixed then new starter after maybe 5 hrs of riding the starter went out im not sure what to do. Please any advice!!
I haven't found a fix yet
I will be putting my 3rd starter in tomorrow since it chewed up another. What could the problem be? The horrible quality of these starters nowadays? Or is it in something with the quad? Gotta put our heads together here.
Have u checked the compression? I'm thinking see if the decompressor is warn down? Causing high compression and being hard on these cheap starters
I have not checked recently, I know it does have high compression though. Would that being worn down cause the starters to keep getting chewed threw?
thanks
