Hi, I am new to the ltr’s and I dont know much about them. But I have figured out that my injector is not getting power when plugged up. It is fine if you test it with a 12v battery. I was thinking the ecm was bad but all the lights still come on, the fuel pump kicks on. Everything works as it should except for the injector.
Best bet is to trace your problem down using the service manual , its fairly simple to follow the steps. Just search up a Ltr 450 owner manual Pdf.
The FI system diagnosis is chapter 4 page 135
I did the diagnostic, it’s showing me a code of “1..12345” “1..12345” I looked the code up in the manual and it’s saying it’s a engine coolant temperature code. I traced the wires back to the ecm and none are loose/broken. I am again clueless.. could anyone point me in the right direction. Oh and why wouldn’t the injector be kicking on if the ect code is thrown?
