I have an 06 ltr and its done nothing but give me problems .... it will not run correctly, I have changed every single part of the fuel system otger than the throttle bbody which I may try... but anyways
Does anyone know of a cheaper way to do a carb kit other than buying the whole kit from williams or walsh? That maybe my best option but idk that's why im asking for advice
blake
I would try cleaning your injector, its not hard to do really. i had to clean mine twice in a weekend, why you ask... contaminated fuel and chitty fuel filter.
get a fcr carb from a yfz or crf 450, throttle cable and you will have to mod the oem thumb throttle. u will need an inline fuel filter and a fuel shut off valve. also a new intake
Discussion Starter #4
Already cleaned and changed out every part of the fuel system, tried all parts from my brothers 08'
But on an update we just got to check the valves and tge valves are double the tolerance...
Ordered shim kit and will update soon
Thanks guys!
